Help Data connection required for MMS messaging?
garybeck
I have my data connection disabled, and I just tried to send my first MMS message. It has said "sending...." for at least 15 minutes now and the recipient has not received it. just a photo attached. Do I need to have an active data connection to send MMS?
YES, data is required to send a text message.
Why is your data connection disabled?
If they're using a Wi-Fi connection it can drain the battery to have 3g on and so they might have it disabled for this reason. I always turn 3g off when I'm using Wi-Fi.
And you can send and receive text messages over Wi-Fi, but from my experience, not picture messages, 3g has to be turned on for that to work.
Data is not required to send/receive a text message, as others have said - just a cell signal. Data is required to send/receive MMS. I think there are some text message Apps that will use WiFi for text messaging, though. WhatsUp might be one, not sure.
