Data Enable Problems...
lcfz86
I wanna ask some kind of quest i dunno did any got this experience...
When i tick the "Data Enable" on my xperia play...
it was auto online with using my GPRS... then i will lost my money on my sim card (couse i'm using prepaid)...
B4 i got my phone wasn't this problems... so i think i was install some software o what i dunno...
can any1 help???
The most likely cause of this would be one of the various background applications such as Email, Timescape etc are syncing via the web. To prevent this from happening I would advise either turning off data when you are not using it or at least turning off background data ( main menu > settings > accounts & sync > turn off background data).
