Help Data Enabled?
mrstlong
I have an LG Volt. When I swipe down I see like a quick menu. What is the "Data" button for?
I have an unlimited plan so do I need this off or on? I am usually on WiFi. Do I need it on when I am away from home?
It just toggles cellular data on/off. Since you have unlimited I'd just keep it on. When you're connected to wifi it automatically disables cellular data :thumbsupdroid:
Turning off data can save the battery, so if you're low on power and wont be able to charge it for a while you can disable it.
But normally you can just leave it on as funkylogik recommended :)
