I split this thread from http://androidforums.com/esteem-all-things-root/562567-mod-data-governor-remover.html
I've done this so that discussion on if it works or does not, personal opinions, and evidence to either side can be discussed here and not pull the original thread off topic, which should remain as a support thread for the modification.
Please do not report this thread so that it can be merged into the thread that I split it from, this was done intentionally. Thank you for your understanding.
Also, the staff of Android Forums does not have any official opinion either way on this issue. I am simply trying to make it so the topic can be discussed in an open manner without detracting from the modification and the work of it's developer.
) everything else was working fine (web browser, youtube, netflix). I guess when I flashed this the website went pretty much back to normal but after awhile it seemed the connection was worse so I reflashed the ROM and everything is fine so I don't know what's up with this mod. I think it was a coincidence though but I haven't used it since.
