Help Data recovery
jonrud
Hi I have accidently reformated my sd card in the note is there a app available to enable me to recover my data photos ect without using a pc.
Best to insert the card into an SD card adapter and connect it to your PC. From there you can use something like MiniTool Data Recovery or similar.
^ +1
If anything, I hope you unmounted and removed the card after the mishap. Any further read/writes on the card will lessen your chances of recovering data. Do not use the card at all until you can extract the data. If you're lucky, you will be able to recover a good chunk.
I think that recover those photos with a PC is more convenient and fast. You have great possibility to retrieve data you mistakenly deleted from Android cellphone. Those files are still in the memory of your phone just not visible, and photo data are waiting to be written over by new data. So from now on don't use your cellphone to take more pics.
The best thing to do is unmount and remove the card, this way it is certain that no more read/writes happen on the card. Also using a computer is more reliable than a phone. You have more equipment and software to play with to increase your chances of data recovery.
Data recovery is not 100% guaranteed regardless of what you use. You also need some luck. Even with deleted data, there can still be corruption of data that takes place.
When files are deleted, they are just left where they are, and the clusters are flagged as unused, so while the directory entries that contains the file name and start cluster are gone, most of the file data should be intact.
More Visit: How to recover data from SD card
The OP said he had reformatted the card.
I'm no expert but I thought that reformatting a card wiped any files on it, whereas simply deleting the files does as you say.
Yes, it wipes out all files, but still retrievable. But not 100% and based on a lot of luck. You also don't want to do any further read/writes on the card as that will lessen the chances of data recovery.
