Help Data Roaming?
Hi, i was just wondering if i should have data roaming on? I have unlimited data and would like to know what data roaming does and whether or not i should have it on?
Thanks
You only need data roaming on if you are away from your network, eg abroad. Even though you have unlimited data on your network, using data whilst roaming will be chargeable, and sometimes it's very expensive. If you have background data enabled you may not even realise you are using it. So probably best to leave it switched off in case you forget. Just put it on if you actively decide to use it whilst travelling, and check costs with your provider first.
Agree with Nij, if you want to use internet on your phone abroad you should definitely check with your operator first. They usually do "bolt-ons" or "booster" that allow you to use a fixed data allowance for a fixed price. For example T-Mob do 20 meg up to a week for
