Help Data roaming
cryo75
Hi all,
In order to turn off data roaming and all other stuff that might incur costs, do I need to just turn off:
Use packet data
Data roaming
Is it just these 2?
Can I have background sync enabled? Does sync use my wifi?
Also, I set up accuweather, my email accounts and yahoo news. Do these apps access online info using wifi?
Thanks,
C
Once you turn data roaming off it shouldnt use any data while roaming, if you use wifi the apps data will go through it
