Data usage alert!
eric70412
Just had a notification pop up on the notification bar saying "DATA USAGE ALERT"!
How do I get it to clear? It just stays there and there isn't a button like you would normally see to clear it from the notification bar!
Thanks
Try settings>Data Usage...> then uncheck the box by "Alert me about data usage". That should do it. I do not know how to clear an alert, perhaps change the allowed amount.
