Data Usage
I'm not a heavy data user, so I just have the mandatory amount you need from ATT (200mb). I've been suspicious that there are some default background apps that might be trickling data constantly, but really don't know which ones they are. Can anyone tell me which apps I can shut down to prevent them from using data?
Thanks
I have the minimum data plan, too. (I almost always use wifi for data.) I use between .5 and .7M of data a day. I just consider that overhead and don't worry about it, it really is just a trickle. Last month I used a total of 23M of data and got a text from AT&T telling me that my data usage was very low. They offered a number to call so that I could be instructed in using the 3G data feature. (And believe me, I use the word "feature" with a huge amount of sarcasm.)
Matt
I'd first go to settings, accounts and sync, and make sure you turn off "background data" and "auto-sync" unless you really need them - but it'll help with data use. You can still manually sync if you want to check for email or something, too. Some widgets that update/sync, just avoid or change their settings so they require manual refresh.
Also, the little power widget is very helpful - wifi, bluetooth, gps, sync, and brightness. I've been using it to quickly toggle on/off my gps/sync.
I also like 3G Watchdog - it really is a great, great app for monitoring data use.
Use Wi-Fi when you can, and CapFAQ has a great tip to keep it on if you use it at home.
Here: Data Usage - CapFAQ
I'd first go to settings, accounts and sync, and make sure "background data" and "auto-sync" unless you really need them - but it'll help with data use. You can still manually sync if you want to check for email or something, too. Some widgets that update/sync, just avoid or change their settings so they require manual refresh.
Thanks for the response. I'll be sure and look at the "background data" and "auto-sync" as you've suggested.
I just posted this is another thread. It may be the solution to your problem.
I use an app called Droid Wall (requires root) to give Wifi and/or 3G access to whatever apps I choose. By default every app is blocked from using any Internet connection. Then, you go in to the Droid Wall app and give access to each app by checking the two check boxes for each app (Wifi and 3G). If there is an app that you want to have Internet access, but only Wifi, you can just check the Wifi box for that app and it will never use 3G.
