A reboot didn't work for me. Clearing the HTC Sense cache didn't work either. It appears to work for some, but it didn't work for me.
GP
How does one know if version dc2.08.1 has been installed successfully?
I used DCupdater which found the updated ROM. I am already running dc2.08.
I downloaded the ROM and then followed the steps but it just rebooted as if I has just turned the phone off, it didnt go into recovery mode or anything as it indicated that it was going to do.
Now if I press the DCupdater it shows the message that dc2.08.1 is available to download...
What to do?
Also my phone is loosing the capability of actullay working as a phone at random times by the speaker/mic and all stop working. I can make calls but I dont hear and I am not heard and the giveaway that it is happening is whn I receive a call the ringer doesnt sound, it just vibrate.
I have to reboot and then it goes back to normal until it decides to do it again.
Any assitance with both issues will be appreciated
Dcv2.08...so I guess it didnt install the update...
Although when I check the changelog in dcconfig it shows version 2.08.1
should I download it again?
if the update doesn't work within the ROM ...download the zip file and flash it through recovery ...
Just rooted my Hero today and installed DC v2.08.1. All was going well until a few minutes ago when I pressed the power button, swiped to unlock the screen and was asked for a password to unlock the screen. Have not had to do that all day. Can anyone help??
it is there now when I click to install the following message pop up..
"No MD5 file according to the update was found.
Do you want to apply it without checking?"
What is an MD5 file?...
Started trying passwords I had entered since installing DCv2.08.1. Tried GMail password first - no luck. Then tried Exchange password - voila! But WHY??? Exchange password is a "strong" password, could never have been entered inadvertently. Thanks for any insight.
