Help DD10 to DE03...??
Ferret
Okay, guys...n00b question...i'm *way* confused, and i apparently need someone to hold my hand, and point me to the Short Bus :o
I've got a Moment..with DD10, rooted...and I want to go to DE03.
I used joey's Zipped installer (to DD03, and then to DD10) for the first update.
Now...am I correct in assuming that the *new* process is:
--Get (and install on your computer) the Sprint Updater
--Get (and install on your computer) the Updater patches to remove the software blocks
--Run the Updater, and Roll *back* to CL14 with it
----Use joey's Custom ROM site to Download the *new* DE03 (i'm picking joey's version), and the neat stuff you want (rooting, Live Wallpapers, etc), and rip the bloatware out by the roots as a .ZIP file
--Install the Custom package using the Updater (Vol Down-Answer-End)
--Reinstall your apps
Does that about cover it?
Sounds about right. If you have the old updater on your computer, you can skip the first 3 steps. I would install the DE03 with Joey's recovery already on it. Also keep in mind that your phone will be wiped during the process.
