Help De-Binging help
y0bailey
Member
Hey folks. Successfully rooted, used Titanium to "freeze" all of the garbage bloatware, and installed all of the google goodies (search, voice search, maps, etc.).
Still having problems. When I freeze or remove Bing, I lose the ability to use the search button. It just says application missing.
I read some fixes on the samsung fascinate, that if you install the enhancedgooglesearch things go back to normal...however I get force closed like crazy until I uninstall it.
Any ideas? Anyone got this to work?
Well you removed Bing, thus removing all of its embedded properties in the phone. That's why your getting an infinite loop task of force closing. You really can't open anything Bing related without getting a infinite force close.
That's strange. I don't have any issues and all I did was freeze everything associated with Bing, install the Google apps and reboot.
When I push the search button it opens Google.
Can you let me know exactly what you froze (like all of the apps)? Did you uninstall or just freeze? Then after that did you just install google search and voice search from the market?
If you don't mind walking me through to make sure I am not missing a step.
Also, just to confirm we are talking about the same thing. I can get google search to work fine. I can manually make google search and google voice search work....I cannot just press the search "soft key" or long press on the "soft key" and have it open up google or google voice search. Instead it either says "application not installed" (after I freeze bing), or opens up bing (if bing is not froze and google programs are installed).
So figured out a fix for now.
Installed LauncherPro. Button now works. Weird, but read some forums about the Samsung Fascinate that used the same fix.
Hope others find this useful.
After reading this I went back and checked and it turns out it was ADW launcher that made it work for me.
y0bailey - Thanks for the tip! I'm now running Gingerbread and using LauncherPro (had to install Home Control first). My search button now opens Google - LIKE IT SHOULD!!! :D
I didn't know that Launcher Pro was making it possible.
I thought it was just because I installed Google Search.
I am running both of those on my UNrooted Commando.
*just letting people know that you don't have to be rooted to get the
search button working with Google.*:)
I HATE BING!!!!
