I was trying to de-brand my Orange DHD a couple of weeks back and have got a little stuck. I believe I have followed all the guides I could find but its just not working.
I have created the gold card (I assume its worked as I wouldn't know how to test it). I am at the step where you replace the rom files between the software loaders. All the files are extracted but when it comes to install them on the phone I get the message.
ERROR[131]: CUSTOMER ID ERROR
1. Does anyone know why this is? Do I need to root my phone when loading the software through this method?
2. If I add data to the gold card will it still work?
3. If I cant get this working, does anyone know a location for a decent de-branding guide for the DHD (I wish it was as easy as symbian).
Thanks,
Jon
Thanks,
Jon
I can confirm you are correct. I was fiddling around last night and learning. It appears when creating a gold card the guides tell you to use the following line to get the memory serial number thingy.
