gunthergloop
I have a Note 10.1 since around October of last year. A few days ago the battery suddenly drained and won't recharge. When I plug it in it recognises that it's plugged in but the charge stays at 1%. I've tried it attached to the pc and it's the same there. Also same whether it's switched on or not. When off, it shows the "battery recharging" animation onscreen, then goes off, then the animation comes on again.
I've ordered a new cable but it does seem like the battery itself to me since even when plugged in, if I run a power-hungry app -such as Sims, which my daughter plays- it seems to drain more than charge, giving warnings and/or shutting down.
My main problem is it's rooted with multiple users via switchme, so if I send it back to Samsung I'm guessing they'll say it's not covered under warranty for this reason (?). I'm not sure I'll be able to wipe & restore the firmware at such a small power percentage even when plugged in -and I'm not eager to try it for this reason.
So, any idea what my options are? I'm in Ireland. I have no idea how to go about this... Any suggestions?
