Gearu
Android Expert
At some point in this process, my GPS has been murdered:
Installed ADW Launcher
Made it how I wanted it (gps isn't touched)
Installed ADB Shell 3D launcher
Wiped data on ADW launcher and then uninstalled.
Now GPS marker doesn't appear in the status bar, only when I try to use an app that uses GPS, and they fail to get a lock.
It's kind of acting similar to having power savings switching it off when not in use, but it's basically non functional.
GPS Status app can only lock onto satellites with the help of network/data connection.
Fairly pissed as everything was fine before and it locked fast, now I have nothing, I tried installed ADW again and fooling with that but the GPS is plain dead.
Tried installing another config file but still no help.
Tried to work this through the touchwiz launcher but it's the same.
edit- Tried to flash LPQ modem with ROM Manager but I get 'failed to verify whole-file signature' and 'signature verification failed'.
