My warranty is over and these problems didn't appear until after the warranty finished. My Atrix has 2 dead spots.
one is a 2cm across the screen. Big enough to make the second row of shortcuts in the home screen useless. I didn't mind this that much because I only used my phone to Talk/Text. It appeared and stayed for 4months, until now.
after that, the second one appeared, just recently, and is 1cm down the middle of the screen. This made texting IMPOSSIBLE with the default keyboard because you won't be able to use the letters "t,g,v" I had to use GoKeyboard's layout, "pad(5")"
GoKeyboard's Pad layout:
https://play.google.com/store/apps/details?id=com.jb.gokeyboard.plugin.pad&hl=en
What should I do? my contract with bell isn't over until another year. Plus, dust got into my front facing camera, making it useless
howmuch would it cost me if I sent it to a repair shop?
and most of all, why is the phone causing these problems?
thanks for your help!
