Help debranding issue.
alankfc02
Hi,
Wondering if anyone can help. I could not wait for o2 to do all there testing on froyo so thought I would debrand my phone. I created a goldcard using 0.0.5 software which said it was sucessful. I then loaded a generic rom. I used this one RUU_Bravo_HTC_WWE_1.21.405.2_Radio_32.36.00.28U_4. 06.00.02_2_release_126984_signed
This installed sucessful. Does this only install if the goldcard is correct?
I then set up my phone and went to check for phone update and it says nothing is avaiable.
This is what my software version says. Can anyone see where i am going wrong
firmware version
2.1-update 1
build number
1.21.405.2 cl174215 release key
software number
1.21.405.2
I would think it would only install if the card was correct yea.
Did you try to get software update with the Goldcard still in or had you put another card back in?
the update could have very well been pulled with the amount of people with complaints for it..
