Help Debugging is not working...
PRkid
My phone is not rooted, just stock (just in case it matters). I plug in the USB from phone to computer, but nothing happens. I have the USB Debugging option, checked. Nothing pops up. The phone charges, but nothing else. I want to transfer files, from my computer, to the phone. Its not letting me do it. Whats wrong?
Slide down your notification bar and there should be one that says USB. Press that and it should pop up with three options to choose from. If you want USB debugging choose internet. If you want to transfer files from your sd card to your computer or vice versa then select mass storage. Thats all you need to do.
I slid down the notification, and there is no option for USB. Nothing at all happens. Nothing on the computer, nothing on the phone.. Except charges the phone :/
You will need to install the drivers. There is lots of threads here in the forum with the drivers links. Sorry for not post them, I'm on the phone using phandroid now.
This happens to me sometimes. Just keep unplugging and replugging in your phone and it should work. If not reboot your phone and pc.
My phone never showed that it was in debugging mode however it always was. I think the notification is turned off by default in super user, but I could be wrong because I dont currently have my esteem right now
I cant safely unmount it from my computer unless I switch it out of Internet mode and into to mass storage or charge only.
