Root deck reloaded and wifi tether
i just flashed the latest rom decks reloaded and i downloaded the latest wifi tether.
I was having issues running the wifi tether because i would have alot of failederrors in the logs. I finally receved no failed errors but the ssid does not broadcast
You need an earlier version of that app. Or, If you're not using 4g you can use the hacked hotspot that is built in. I wish I knew more info, but I don't ever use those apps, and frankly I don't even know how true the info is I gave. I'm just typing what I've heard is all.
