Root Deck's Reloaded .44 fans/experts...help!
dkl1
Android Expert
Ok. Where to start?
I bought a 16GB C10 sdcard to replace my orig 8GB card for the Evo and I partitioned it. Maybe I went too far with that...EXT4? The card seems to work ok but after flashing Deck's Reloaded, it seems that my apps are NOT beeing loaded onto the sdcard! I've tried some of the prescribed Terminal Emulator entries but always comes back "a2sd NOT FOUND". Do I need to flash it!
Also, messages. After the flash, my messages are not restoring. I did a nandroid and TB update.zip and figured it would restore all my stuff. No! Where do I need to get to retrieve the messages retore files? Then, once there, where do I need to put them? Thanks for the (much needed!) help :o:)
Ok. Where to start?
There were 2 options to flash Decks....with or without a2sd...do you remember which method you used? If not, you can still flash the dta2sd script.
As far as your messages, I do not know but I'm sure someone else will see this and know:)
Can't remember specifically but I'm certain I would have chosen "WITH"!
I'm pretty sure titaniums update.zip feature is just a flashable way to get titanium backup on the device. It doesnt restore anything and I find it quite useless. :thumbdown:
Id rather just download it from the market so I know its updated.
With the messages... Are you talking about texts? You should NOT he backing up the messages app since that is a system app. You can use a different app to back up texts if they are important but I personally like having all the clutter cleaned out after a fresh flash.
