So after nearly 2 wks with my desire I've got a problem and want to know if anyone else has the same issue?
I use my phone for business so calls are important, but whilst a customer is trying to ring me, as i reach into my pocket to pull the phone out or go to pull it out of my desire case on my belt i end up rejecting the call. The prob seems to be that as a call comes in the screen gives you the option to answer the call by sliding your finger down or to reject the call by sliding it up. This is a nightmare especially when the customer has witheld the number.
After nearly an hour with both an orange call assistant and a technician from HTC, they seem to be saying that its the way i am picking the phone up, their advice is to get it out of my pocket without touching either the front or back of the phone, just to handle it at the sides(not a simple task when your sat down and your phone is in your front pocket of your jeans) The other tip was to remember to put the phone back in your pocket with the screen facing outward......funny i don't seem to recall seeing that in the instructions????
never had this prob with the LG VIEWTY, HTC TOUCH OR IPHONE.
So my question is is anybody else having this prob or do you think that I've got a fault on my phone?
never had this prob with the LG VIEWTY, HTC TOUCH OR IPHONE.So my question is is anybody else having this prob or do you think that I've got a fault on my phone?
