Lanman1978
How to prevent the Triumph from going into deep sleep?
NM found an app to keep my wifi alive. That is all I was looking to do anyway.
if your on CM9 there is an option you can enable to keep wifi on without any need of an app
You can do this on all the roms under wife advanced settings and change the sleep policy!
Open WiFi like your going to add a new network and use your hard key far left and then goto advanced.
thanks for the info i always forgot there is hard keys im so use to touchscreen everything lol i would thank B_randon but he didnt tell how to do it
well he did answer i guess i can 'like' it lol
