default alarm clock alter swipe to disable
chezybezy
i just know when i use the alarm for the fist time (Wednesday) when i lean over n try and press the snooze button im going to end up making the swipe motion and disable it by accident.
is there a way to either move the swipe to disable section (i didn't really want to change the unlock action with a personal one) or just make the snooze button huge?
or am i looking at a new different alarm clock app?
Did you check the options in the settings?
Go in to the alarm, press menu, then settings. Under Slide Behaviour you can deselect it.
thanks but maybe im missing something i dont seem to have an option for slide i do however have an option for side button behaviour (i belive this is the volume up/ down button?). just in case i tested it and set it to none and if i swipe downwards it still stops the alarm (im assuming this doesnt snooze it?).
if i leave it on deskclock night mode i do get buttons rather than the swipe thing, i guess im stuck with swipe to disable?
