Trying to get my Droid X to update to .340 and having problems, it keeps failing. I did remove some bloatware but I must not have installed them all back. Is there a list of the default apps so I can make sure i have all the right ones?
If he SBFs, there's no reason to make a backup. Any backups made on .15 or earlier won't work with .320 or .340. OP, check out this thread, there's a zip with all the bloat.
