Help default browser question
ekloot
Has anyone else noticed that when you want to type in a text box that is near the bottom of the screen using the standard browser...the on-screen keyboard covers up the text box and you can't see what you're typing? If you go to the google homepage and then scroll to the bottom where there is a text box and then try to type in there, it happens. Happens to me a lot in the browser when on facebook...while I'm trying to comment on a thread (since the comment box is at the bottom of the screen). I know I could just slide out the keyboard and avoid this problem, but is there some sort of setting that I'm not aware of that would keep the text box visible for when I'd rather use the on-screen keyboard?
