Help Default Calendar Galaxy Note?
enduser2941
Member
Hey all, The galaxy Note has a calendar in it that I really like, I think it is the default calendar that is available with the TwLauncher. The question that I have is that I can use this calendar even though I am now using the GO Launcher EX, but I can't seem to find a widget for it. The GO Launcher EX calendar widget / calendar is OK but it doesn't show you what is going on that day unless you click on the day and then it brings up the day and all it's events. The calendar that came default under the Tw Launcher shows you in words what events are for any given day. Is their anyway to get this calendar's widget to work with the GO Launcher? or are the widgets limited to the Launcher you choose?
Thanks once again for being patient with me and answering all my n00bish questions!!
Nope - that is TW Launcher widget only.
Ok, thats what I kind of figured. That being said, is there a way to convert the widget to work under a different launcher? Or should I just d/l a different calendar app such as Jorte? I think that's how you spell it. Do apps such as Jorte which I have used under the Tw Launcher pretty much work using any Launcher? Or are the apps in google play very specific to the Launcher itself or will their widgets work just under specific Launchers?
I do appreciate this as I am new to playing around with different Launchers and I became a fan of the look and feel of the GO Launcher EX look and feel, but it could be a deal breaker for me if the apps I like only have widgets which will work only with specific Launchers.
I don't have a Note yet but I do use Go Launcher Ex on my HTC Desire and it's a great launcher. I have downloaded and tried several different calendars including Jorte and Business Calendar and also severeal different calendar widgets. Lots of them are free to try so it's well worth downloading and trying some until you find one you like.
I have used Jorte before on my HTC Inspire an I really liked it, however, when I got the Galaxy Note, it comes with a calendar app that is similar in function to Jorte but is a little cleaner and offers some additional features I like alot, but it's widget is not compatible with the GO Launcher EX, which really sucks. I may go back to using Jorte IF it's widget is compatible with the GO Launcher.
