Help Default Email for Sending Picture
DyLinn
I'm trying to figure out how to change the email address that is used by Default when sending a picture. When in Photos, I click "Share via" and Email. The email address that comes up as "sent from" is one of my secondary email accounts. I've looked under Settings, Applications for every app I thought might be related. I've sent another picture changing the From email manually, thinking it just remembered the last email address I used, but so far nothing has worked. Any suggestions greatly appreciated!
This isn't REALLY the answer to your question, but it might sneak you by the problem.
In the email app there should be an option to use a specific account as the default. If you change the default email to the one you want to use to send pictures that SHOULD be the one it uses.
For Pete's Sake! I had my main account as my default at one point.. not sure how it went away, but that was the solution! I had even thought that the Photo Program should use my "Default" mail account and couldn't figure out why it wasn't... but did I go check to see if it was still set as Default?? NO!! Duh... checked everything else, Googled myself silly, but didn't look at that one setting! Thank you so much!!!
