Help default ringtone selection
chief_p
I no longer have the option Android System or Select Music I install ringtone extender and I had the option to selection ringtone extender or android. I mistakenly selected check box android as default and now I cannot get the option back. I searched the forum and could not find an answer. Does any know how I could get this option back?
Go to your settings>>applications>>manage applications>>On the ringtone extender press the clear defaults. That should do the trick. Or try uninstalling ringtone extender and then reinstalling it.
I had tried clear defaults and it was grayed out ( no defaults set) I uninstalled and reinstalled rings extended several times, same problem.
I was told by samsung support that a master reset was the only way to clear that default, and thats what I did and it solved the problem. Thanks
