Help Default text messages when declining a call
Welcome to the forums :) I'm not sure if you ever found the answer to this question?
I've been meaning to get on here for a week (or almost two) and provide a reply :o
If you need to turn on or off this behavior, when declining calls, it is located in Settings -> Call -> scroll down and select or de-select 'Declined Calls'
The way that you can edit these default messages when declining calls, also called "Quick Texts", is to:
Go into the Messaging Application -> Select and open a message thread OR compose a new message -> Menu/3-dot overflow button -> Quick Text -> Menu/3-dot overflow button -> select Add, Delete, or Edit accordingly
