Help Default video player won't scale to full screen
LunchBB
Disappointed to find out the default video player won't scale the video to full screen. It's just a tiny window in the middle. ahhh...
whatever file I play, it should scale to full screen, or at least have an option to scale full screen or not.
I now use another video player which scale full screen. However, I like the default player that will dim down the 3 control buttons on the bottom left and the time on the right.
Mine scales to full screen if the video's resolution will handle it. Even when it isn't playing full screen, some of the youtube videos are pushing the limits of viewability. I don't have an issue with it the way it is set up.
Aha, i think you'd better refer to some professional testing result of different players for galaxy tab. ok, for example ,if you want to play mkv on galaxy tab ,you will encounter some problems, as far as i know, galaxy tab support the Mkv files, but on different players, it has different effect:
on Moboplayer,galaxy tab support the 1080p mkv video,
while on Vplayer, play 1080p MKV video unsmoothly,
and Rockplayer unsupport 1080p mkv is unsupported on Rockplayer,
so i think you'd better view the professional testing result of different players(you can go to:Convert video to Galaxy Tab for different media players with best Galaxy Tab Video Converter) .
by the way, maybe you already know that galaxy tab only support some video formats, and ig you want to play DVD or Blu-ray on galaxy tab, you need convert them to the supported formats of galaxy tab.
And i think galaxy tab is great, every thing has two sides,right?
so i think you'd better view the professional testing result of different players(you can go to: Convert video to Galaxy Tab for different media players with best Galaxy Tab Video Converter)
