B
brightness
Guest
Hi there,
I have heard that linux does not need defragging as the EXT file system is not prone to fragmentation as NTFS does.
So, android is from linux, does it mean that it does not need defragging even if you frequently install and uninstall apps?
Also, how can you uninstall default apps that you don't use (like roadsync) without rooting the phone?
