SVS is Static Voltage Scaling, which means that there's a fixed voltage for each cpu frequency.
HAVS is Hybrid Adaptive Voltage Scaling. With this the voltage is adjusted according to both clock speed and temperature.
In principle HAVS kernels can use less power, by running at lower voltages. But different handsets have different tolerances for this. Sounds like the 875mV minimum of this kernel may be too low for yours.
The HAVS 925mV version might be more stable - this is the same principle but a higher minimum voltage. SVS kernels don't typically go to as low a voltage, and so tend to be most stable. The default kernel will have been one of these.
CFS and BFS are different scheduling algorithms (how cpu cycles are shared between tasks). With 2.2 BFS was (in my experience) more responsive, but with 2.3 everbody seems to report CFS being better.
The 1190 SVS kernels have stability warnings because not all phones can cope with the high overclocks, but then it's up to you whether you select that. That will anyway reduce battery life, so I doubt they are of much interest to you.
I'm currently experimenting with other kernels apart from those downloaded via Villain Setup (tried vork, currently trialling eviollet's GB kernel, not tried coutts' yet).
