Root Defrost Rom Email Problem
Murgy91
Hey, just changed to defrost rom.. works brilliant this time!
Only problem is the email... on the default rom it allows you to skip past options if it cant connect to it.. eg not been able to connect to your smtp server. if it canbt connect it says cant promise it will work while sending but you can continue.... if that makes sense lol.
With this one if it doesnt connect it wont let you.
My email smtp is smtp.dsl.pipex.com
However i believe the three network which i am on block the port this ISP uses... so i cant send mail from my phone.
How can i get round this? im not to bothered about the fact i cant send... but because of the menu option it wont let me finilize to recieve?
im so rubbish at explaining myself...
Hope this makes sense guys?
Luke
Luke
Does the rom provide you with the option to set up manually, as this may provide a way round it
I don't have accounts n menu and under settings it doesn't work tried already...... I'm having a problem downloading things from the market now.... hmmmm any ideas was getting k9 but cant download anything now.... any ideas?
Open email and press menu and choose accounts from that menu. In the accounts screen press menu....etc
Did you install.the radio when you installed the rom?
Did you do a wipe?
If so did you restore anything from your previous Rom?
Using what and what did you restore?
