Something really annoying about my Rezound: whenever I open up someone
Its probably just the sheer volume of contacts. Remember that WiFi and Mobile Data usage would have no effect on this, it is done locally. I have about 160 contacts and the delay is barely noticeable, but is definitely there.1,064. It's probably the merging upon display, though it's beyond me how this can be happening when I have both Wifi and Mobile Network turned off. Also, this happens with ALL entries, not only those which are linked to another.
Then you never went from Windows 98 to ME, or from Windows XP to Vista.Then it's just awful design. I had a similar number of contacts in my old Palm Treo, which had no such problem. On the Rezound, it seems like everything is slow to react. It is the first "upgrade" in technology I have ever experienced where I am really missing my old system.
It is not doing that... I don't think you understand how the contacts work, they are stored locally on the device and synced at intervals exactly as you wish it did. I am not sure how the FB app interacts with that, but I use it regularly and have not seen the issues you describe. Anyway, glad you got it fixed.Finally fixed it. The only way was to remove Facebook as an active account. Even turning off Facebook synching and turning off all integration options did not do it.
But I am really disappointed in Android. Having to download contact information from the Internet every time one opens a contact is very poor design. If the information were actually synched to the local contact at regular intervals (as it claims to do) it would work better.
Then you never went from Windows 98 to ME, or from Windows XP to Vista.![]()
Hmnmm... lag and delays have never been an issue on my Rezound (and I have two, a personal and a work one), I can compare it to several phones (Casio Commando, Samsung Stratosphere, HTC Incredible 2, Droid Bionic, Motorola Razr, Droid 3) and compared to any of those it is extremely snappy and responsive. I would strongly recommend a factory default and try again, especially if you haven't done it with any of the OTA upgrades over the last year.Actually, with respect to downgrading, I was thinking more in terms of hardware. New hardware *should* be faster and more responsive than old hardware, but my Rezound, while pretty, is beset by delays throughout. That's the main reason I was hoping we would get Jelly Bean: it's supposedly been optimized for speed and responsiveness.
In the short term, I've installed GO Contacts EX, which does not suffer from the lag the native Contacts app does.
