Delayed screen on
I just updated to 2.2 from Telus less than a week ago and since then I had been having some slowdown issues, both in the browser and just the OS in general. I decided to do a factory reset yesterday, and it seems to have fixed the slowness. However now I've got a new problem.
Sometimes when I press the power button to turn the screen on, there is a delay of up to 10 seconds before it turns on. Sometimes the backlight on the buttons will go on right away. Originally I noticed this when connected to AC power but it's started happening on battery as well.
Has anyone heard of this or heard how to fix it?
Could be an app problem. Uninstall all your apps from the market, then re-install one by one checking each time you install an app to see if problem appears.
