Help Delete words from Android Keyboard?
thlax
My Gs2 on ATT has 3 keyboard options (swipe/samsung/android, as i suppose all ATT GS2 do.). I use the android keyboard. There are a couple words it has remembered from somewhere and such that i don't care for it to remember.
Such as I once knew a person name Rhe years ago, deleted their contact over a year ago, (i guess was once in my google address book but no longer is-all my contacts come from syncing my google account, currently they're not on my phone's address book as it should be..... but when i type "the" too fast as "hte" sometimes and miss spell it, it still gives me an option to use "Rhe".
Also, every now and then, it gives me the option to add an extra letter at the begging or end such as "wayy" or "tthe" from previous times i sent a text with that in it and did not notice it was wrong.
I know if you type a new word you can select it from the bar above the keyboard and it says tap again to save, but i never do.
I know in the advanced settings for the samsung keyboard you can make short cuts and custom dictionary...but i see know support for the android keyboard settings. How do i do i edit the custom dictionary and such for the android keyboard?
Help??
-David
Click an empty space on one of your homepages (it doesn't matter which page) continue pressing until an option bar appears underneath said homepage..click shortcuts....scroll down to settings...scroll down again and near the bottom you will see user dictionary..you can create a shortcut onto a homepage and then edit these words.
Your the man. Thx!
So apparently that isn't available on the Galaxy Infuse - any other ideas?!?
Thanks!!
