Root Deleting Apps...HELP
McKenna
I downloaded Android Mate and Root Explored and when I am in Root Explorer I am unable to Mount R/W. I click on the button and it highlights yellow but it doesn't change access for me and I can't delete the apps I don't want because it's still in read only mode. Advice?
I would suggest to root your phone :)
Or if you are already root user, unroot it and re-root it using Z4root. That hould do the trick.
1) Root your device
2) Install custom recovery
3) install my rom
equals simple
Are you running Android 2.2 or 2.2.1? :confused: Some Optimus M are coming with 2.2.1, while the original batch (luckily) had 2.2. Also, some people who don't know better are "upgrading" to 2.2.1 from 2.2 -- and now cannot root.
2.2.1 cannot be rooted at this time. You would have to downgrade to 2.2.
