Help Deleting calls
Welcome to AF Angellvr. :hello: I don't have your phone it you can try and long press the number and see if an option for delete comes up.
in your contacts, hit the menu button, then hit select items then select what u want deleted then hit delete. in call logs hit the menu button then hit clear logs and it deleted all logs. if your just wanting to clear a individual log then click on the log u want removed then the menu button then click remove from call log
No menu button comes up other than to add the call to my contacts. Pressing and then holding the number doesn't work either.
in the contacts screen. push the far right button. the one just to the right of the home button. then click select item. then after you have selected it hit the delete button on bottom right corner.
I'm sorry your talking about call logs now. to delete a call log, while inside your logs, press the desired call u want deleted. it then goes into the details of the call. then click the menu button to the right of the home button. you then get the option "remove from call log" and option "edit number before call" :D
If you want to delete your call log, simply go into Phone, Call Log, hit the bottom right key on your phone, click Clear Call log. (If this option isn't available something must be wrong with your phone.)
If you want to delete your contacts, I think you'll have to either do each manually, by selecting Select Items, then select all or the contacts you wish to delete, then hit the trash can button on the bottom. If your contacts are synced, I'd recommend you disable sync under Accounts, or unlink the account, before going on a contact removing frenzy.
(Hope this helps in a nutshell, even though the problem appears to have been solved.)
