Help deleting custom scenes
kintal
It seems a long press on the name of a custom scene in the scene select menu should give you the option to delete.. but no luck here , anyone else found this or know what i'm doin wrong.?
Ta
You have to find them through the android settings, not though the option on the homescreen. Then you'll be able to delete/rename them.
Sorry I can't be more specific than that, but it's been a while since I used HTC Sense.
