Deleting folders after flashing?
After you are done flashing can you delete the folders on the SD drive?
If you're refering to the rom zip files, yes. You no longer need them after you flash the rom.
I recommend keeping it handy on your computer, as sometimes a reflash might be needed to clear up some bugs.
