imronburgundy
Ok so I finally got my ota 2.2 rooted. Does anyone know if I can use the previous deodex method or is there a different way on ota? Needs my themes back.
Fyi, I got it deodexed using the black hat app. Worked fine in case anyone is interested.
I followed that link and all went just like a charm.I followed the link to get xultimate v2.2.2, but avg is going nuts saying the executables all have trojans in them.
Is there a link for a clean version anywhere?
There is such a thing as a false detection. If countless others are using the exact same files from the same location, I wouldn't worry much about what your AV is spitting out.I followed the link to get xultimate v2.2.2, but avg is going nuts saying the executables all have trojans in them.
When entering the code do I enter each line then press enter, or all of it at once?Process:
Code:
- Unzip xUltimate v2.2, and launch "Main.exe"
- If everything goes well xUlt should recognize the phone and make a connection. You now should see a list of options.
- Run option 1. After option 1 is done, run option 2.
- Now these well take a while. Run option 3.
- IMPORTANT: After you have run option 3, you MUST navigate to the xUltimate folder and find "origi_frame" folder, and delete "guava.odex". It's a bad file, and interferes with deodexing process.
- Now run option 4, and wait.
- Exit xUltimate, and put the phone in USB mass storage.
- Go back into the xUltimate folder and copy "done_frame", and "done_app", and move them to the root of the sdcard.
- Open a command prompt, and do the following:
adb shell su stop mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system cp /sdcard/done_app/* /system/app/ cp /sdcard/done_frame/* /system/framework/ rm /system/app/*.odex rm /system/framework/*.odex mount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /system reboot
BuellerWhen entering the code do I enter each line then press enter, or all of it at once?
The quote somehow messes up the formatting. Those commands are supposed to be on separate lines.When entering the code do I enter each line then press enter, or all of it at once?
adb shell
su
stop
reboot
Plug the device into your computer and make sure that your USB mode is set to, "PC Mode." Bring up the command prompt and make sure you're current path is where your Android SDK's, "tools," folder is located. It should be something like, "C:\android\tools\" Now type, "adb devices" (without quotes). It should show your device as being connected. If not, you may need to reinstall drivers. If it does list your device, then go ahead and continue trying to access the shell.
C:\Documents and Settings\Owner>adb devices
'adb' is not recognized as an internal or external command,
operable program or batch file.
C:\Documents and Settings\Owner>cd desktop/android/tools
C:\Documents and Settings\Owner\Desktop\android\tools>adb devices
List of devices attached
015D778F17014015 device
C:\Documents and Settings\Owner\Desktop\android\tools>adb shell
# exit
exit
and it spit back the # symbol when it seemed to be done but when I then put inrm /system/framework/*.odex
it spit the cmd back and told me something about the system or device being busy. was the same way for over 10 minutes and the phone was unresponsive to any touch or button push. I exited out and unplugged then had to pull the battery, everything rebooted fine (took a while on the eye though) and I just want to make sure everything worked right before i try to apply a theme and screw everything up.mount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /system
Does anyone know how I can make sure this worked? I put in step and it spit back the # symbol when it seemed to be done but when I then put in it spit the cmd back and told me something about the system or device being busy. was the same way for over 10 minutes and the phone was unresponsive to any touch or button push. I exited out and unplugged then had to pull the battery, everything rebooted fine (took a while on the eye though) and I just want to make sure everything worked right before i try to apply a theme and screw everything up.
I had all of this happen to me the first go around as well.Does anyone know how I can make sure this worked? I put in step and it spit back the # symbol when it seemed to be done but when I then put in it spit the cmd back and told me something about the system or device being busy. was the same way for over 10 minutes and the phone was unresponsive to any touch or button push. I exited out and unplugged then had to pull the battery, everything rebooted fine (took a while on the eye though) and I just want to make sure everything worked right before i try to apply a theme and screw everything up.
