So, I attempted to deodex my phone with xUltimate..PROBLEM
If anyone might have a suggestion please let me know:
Any help is appreciated..
Also I have tried to google it.. no luck. but that doesn't mean it's not out there.
ERROR:
ERROR:
Code:
Starting AccountAndSyncSettings.odex
* Deodexing... *
UNEXPECTED TOP-LEVEL EXCEPTION:
org.jf.dexlib.Util.ExceptionWithContext: regCount does not match the number of a
rguments of the method
at org.jf.dexlib.Util.ExceptionWithContext.withContext(ExceptionWithCont
ext.java:54)
at org.jf.dexlib.Code.InstructionIterator.IterateInstructions(Instructio
nIterator.java:92)
at org.jf.dexlib.CodeItem.readItem(CodeItem.java:154)
at org.jf.dexlib.Item.readFrom(Item.java:76)
at org.jf.dexlib.OffsettedSection.readItems(OffsettedSection.java:48)
at org.jf.dexlib.Section.readFrom(Section.java:143)
at org.jf.dexlib.DexFile.<init>(DexFile.java:431)
at org.jf.baksmali.main.main(main.java:265)
Caused by: java.lang.RuntimeException: regCount does not match the number of arg
at org.jf.dexlib.Code.Format.Instruction3rc.checkItem(Instruction3rc.jav
a:129)
at org.jf.dexlib.Code.Format.Instruction3rc.<init>(Instruction3rc.java:7
9)
at org.jf.dexlib.Code.Format.Instruction3rc.<init>(Instruction3rc.java:4
4)
at org.jf.dexlib.Code.Format.Instruction3rc$Factory.makeInstruction(Inst
ruction3rc.java:145)
nIterator.java:84)
... 6 more
Error occured at code address 8
code_item @0x2370
Press any key to continue . . .
