Root Deodex Problem - mount: Device or resource Busy
g3on3o
Droid X - 2.2 - Rooted
Attempting to deodex, followed the instructions exactly on this thread (http://androidforums.com/droid-x-al...w-manually-deodex-your-phone.html#post1477490) but on my last step when entering "mount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /system" I get the following response from cmd prompt, "mount: Device or resource busy"
The OP said I should try placing the phone in Charge Only mode or whatever it's called, as opposed to USB Mass Storage, just tried that and again, same message.
If no ideas how to fix this, does anyone at least know what to do so that when I reboot I won't have to do a Nandroid restore? It's getting really annoying going on the 3rd or 4th time
Thought I'd get more assistance posting here than IN the actual thread... Thanks in advance!
Mine did the same thing, I just continued with the rest of the directions after letting it sit for 30min while I was looking on forums for a solution.
Everything booted up fine for me after that.
