Root deodexed vs odexed
crutoi
Member
Hi,
i did a bit of reading and still trying to find all the differences between deodexed roms vs regular roms
so far this is what i have found, if some one can add to this please do
Pros:
enables for more UI customizations(themes, fonts, title bar icons, like battery icons)
Cons:
slower to boot
this is the explanation of deodexed that i found:
"Apk files have respective odexes that devs use to supposedly save space. Deodexing means you convert it back to a .dex file and put it back inside the apk. This allows you to easily replace files (not having to worry about odexes), but the main point was to deodex services.jar so that you can change all text to different colors (such as the clock color to white) and to deodex services.jar, you need to deodex everything. "
deodex: easier to tweak, lighter on ram, heavier on space.
odex: easier on space, tougher on tweaking and ram usage.
You have a far greater chance of something being broken with a de-odexed rom due to the generally buggy nature of deodexing.
Thank you for the explanation.
thanks one great explanation for me..been digging up and down for all these... new on rooting stuff...
Thanks,
Ok, I have some more noob questions:
1) If de-odexing gets too buggy, can I RE-odex?
2) What is the most straight-forward way for someone to deodex? Droid X has a snappy java utility but I haven't found anything this simple for the DInc.
Thanks a lot :)
Thanks a lot :)
You personally won't be doing any of it, unless you plan on developing.
This basically refers to whether the ROM you are installing is odexed or deodexed. I haven't had trouble with either type so far.
