The Desire has very limited internal memory, which is "fixable"
sorry if this seems stupid, but im new to smartphones!
can you not just use a sd memory card then to store things? or does the phone not allow that and you have to save to internal memory?
thanks again
Andy
so do you think 250mb per month for out and about stuff would be ok! then just turn it off when i get warnings,,, then nip into mcdonalds! haha
Because of this a lot of people seem to run out of internal memory. I have around 50 apps installed and I've not run-out (I've got about 35MB a.t.m). I'm also happy to delete a load of unused apps if I get any closer to full and need to install something new. Some people have had problems with email and contacts taking-up large chunks of their phone memory, there are fixes for this. Others seem to want to install every app on the planet (even if they're never going to use them).
Yes I bought a smartphone expecting to have this world of unlimited internet and apps to play with then was quite surprised when I hit a wall with the memory limitation.
I can't delete stuff I "might" need, just the same with my PC - I just add a new harddrive hehe![]()
thanks, much appreciated, the
You do have an unlimited world available - you just have to sample it a bit at a time (in the same way you do with your PC, you cannot buy infinite disks). I mean, it's not as if the Desire isn't constantly connected to the net with several market apps available to download apps as you need them...
This is the fix:can you elaborate on this? my email was taking up over 100mb and everyone keeps saying "clear the data" when that button is not highlighted!!!
what is the fix?? please...
