Accessories Desire and Jabra BT3030...work?
mcnob
Am thinking of getting the unit for cycling but wanna know if anyone else has tried it with the Desire and if so...do the controls work OK?
The Jabra BT3030 is the bluetooth stereo headset adaptor that looks like a dog tag and you can hang it around your neck or clip it on to your clothing.
So......anyone?
I have the BT3030 and it works just fine for answering calls and listening to music.
Haven't managed to get it to work with voice dialling although the manual claims it should be able to.
You might find it better to use the clip rather than the chain to wear it as it tends to swing about when you move, moving the microphone away from your mouth periodically.
