No-one knows then!!!![]()
Switch-mode power supplies are extremely efficient. If you left it plugged in day and night for a whole year, the cost to you would be approximately
OK. So, I've unplugged all my appliances, turned all the lights off and put the Desire on charge. The candle has burned out and ruined the cake. I'm cold, hungry and bored. The meter hasn't moved, and I'm getting cramps from sitting in the cupboard under the stairs for the past 4 hours. However I will persist for the sake of this experiment.
OR.....
I'll nip over to an electricity cost calculator and work out that it costs 24p a month to run 1 amp for 7 hours a day if leccy costs 15p per kWh.
Anything else you need help with while I'm here? Tying your laces? Telling your arse from you elbow?![]()
OR.....
And that's assuming it draws 0.2 amps constantly for 7 hours, which I don't believe it does. Basically, it's cheap as chips. Much cheaper these days actually!Is this guy in Russia living on coal power? Something tells me if your worried about how much it costs to charge the phone.. you should'nt have the phone...
Purely out of interest, does anyone have an idea what it costs in terms of juice/
Do you understand what 'purely out of interest means' my young friend?
By the way - it's 'you're' and 'shouldn't'. Tell teacher tomorrow so you can practice.
I'd give up if I were you - fighting a battle of wits whilst unarmed is not a good idea..
WozzaTT said:Aaaah yes...........Essex!!
)I'd give up if I were you - fighting a battle of wits whilst unarmed is not a good idea..
"Respirator"
I didn't say what the charger used. I simply said what it cost for 1 ampWrong. The charger puts OUT 1 amp. It draws 0.2 amps, giving a cost per month of less than 5p if power is 15p per kWh.And that's assuming it draws 0.2 amps constantly for 7 hours, which I don't believe it does. Basically, it's cheap as chips. Much cheaper these days actually!
