Desire, Exchange PIN/code & LockPicker
TobesEtc
UK HTC Desire on Vodafone, currently 2.1:
Don't laugh...
I recently set up my calendar to sync with Exchange, which worked perfectly. However, the security of Exchange meant that it insisted on having an unlock code.
Then I installed LockPicker to circumvent having to type in the code every time I used the phone. This also worked perfectly.
Now I've forgotten what the code is. Which doesn't matter, as LockPicker is still working fine. However, I'm on Vodafone, and rumour has it that we'll be getting Android 2.2 this week. Now, call me Old Mr Cynical, but I'm seeing a potential problem here... if LockPicker doesn't reinstall/transfer to 2.2 first time... I'm not going to be able to get into the phone!
So, before this all goes very pear shaped, is there a way (other than Factory Reset) of getting around this? Or, if I have to do a FR, then what's the best way to avoid aggro after the reset and get everything back how it currently is?
...I said Don't Laugh! ;o)
When you get the promt for the update, install mybackup pro 7 day trial and back everything up. Then do a seperate backup just for the lockpick app & data.
Restart the phone, and you'll be reprompted for the update.
