When you say finished, do you mean flat? Because if it is completely flat then nothing will work. I think that all mobiles will operate the alarm even when switched off but that still requires some level of charge.
The solution would appear to be to charge it at night while you're sleeping assuming you have a power point in your bedroom.
You will be just fine. The phone knows when the battery is full (charging light turns green) and will not push anymore juice into it.I know I can put it all the night in the charge but is there a problem about the battery when it got full and keep it in the charger a lot of hours ?
do you know how to get the alarm to work when the phones turned off overnight. tweeked a few settings in the alarm but its not working. cheers
You can't...because it's turned off![]()
It's not such a silly question. With all my previous handsets I have been able to switch the phone off before I go to bed and have the alarm go off when it's supposed to in the morning.
That's kind of true, there are features built into the phone and charger to limit over charging; however its impossible to stop this without a physical switch. There will always be a small current running from the charger into the phone if there is a wire connecting it to the mains.You will be just fine. The phone knows when the battery is full (charging light turns green) and will not push anymore juice into it.
once the device is turned off,,,the alarms will not ring....You can't...because it's turned off![]()
