Root Desire HD Cronos Ginger X 1.7.0
Feeyo
Hi guys,
Here is a new release of your favorite Cronos ROM for your Device. This time it has the first release of Cronos X included.
This is still WIP (Work In Progress) by me and Computerfreak so please dont go flaming us about features that are not included.
If you have a wish list of functions please use a proper Forum thread to post them so that we can have a look at it.
NOTE: DOES THE PHONE FEEL SLOW AFTER THE FIRST FLASH?
GO TO X SETTINGS, CPU SETTINGS AND CHANGE THE MINIMUM AND MAXIMUM SPEED TO YOUR DESIRED SPEED.
I HAVE HAD TO PUT A LOWISH DEFAULT THAT IS SAFE FOR EVERY DEVICE.
Release Notes:
15 Jul 2011 | Cronos Ginger X 1.7.0
  • First release of Cronos X.
    • Settings have extended options.
    • Font size options ported by ComputerFreak.
    • Battery Percentage option added.
    • Battery Percentage Bug, fixed by ComputerFreak.
    • widget button FC on MDPI devices fixed by ComputeFreak.
    • Improved Danish Translations by ComputerFreak.
    • Extra animation option ported by ComputerFreak.
    • small GUI changes by ComputerFreak.
  • A few tweaks used with flags.
  • Fully Removed CM Extra.
  • Sources have been updated to latest AOSP.
  • Source for external and hardware support updated to latest CM.
  • libSqlite improvement.
  • Added Call Delay tweak by jyxent.
  • lowmemorykiller improvement (Again)
  • Added a few tweaks from Juwe11.
  • BatteryWipe on flash by Seo.
  • And of course all the Cronos speed imrpovements Added.
09 April 2011 | Cronos Ginger 1.6.0
  • Resampler optimization routines properly patch.
  • TextView.setText memleak fixed.
  • SW renderer of Stagefright move on to draw stage after the initialization.
  • Fixed isValid() Software EGL Rendering seg fault.
  • Default WiFi sleep policy added.
  • Added sdcard tweaks.
  • Removed Default Camera.
  • Removed Default Music Player.
  • Added MIUI Camera.
  • Added MIUI Music Player.
  • Changed some compile optimizations.
  • Faster GUI Animations.
  • Updated to latest CM Extra. (By CM Team)
    23 Mar 2011 | Cronos Ginger 1.5.0
    • OOM Error encoding images.
    • Fixed contact data updating.
    • Fixed Launcher Menu (more) Replication Bug.
    • Fixed Heavy Graphics Load System Crash. (Library Exception)
    • USB remount SDCARD Patch included.
    • Gralloc Mem Leak Fix.
    20 Mar 2011 | Cronos Ginger 1.4.0 Patch 1
    • Fixed USB Mounting.
    • AccessibilityManagerService death notifications proper clean up.
    • Removed dead store : core/java/android/os/BatteryStats.java Patch2.
    • Improved shutdown speed.
    • revert PIXEL_FORMAT_RGB_565 (By Nadlabak)
    • Improved Camera preview format.
    • Updated to latest source updates
    • Included hrkfdn kernel.
    • Bug fixes of DRM framework
    • Removed dead code with no other effect than consuming battery life.
    • float values equality checks : core/java/android/webkit/WebView.java.
    • frameworks/base: Fix for force close during rapid FF of cetain midi clips
    • Runtime inclusion of services in the SystemServer with overlays
    • Fixed memory leak in PreferenceScreen.
    • Removed strict lowmemorykiller configuration.
    • Should be nicer to battery life.
    13 Mar 2011 | Cronos Ginger 1.3.0
    • Updated to latest sources.
    • Re Added EXT4 formatting to install.
    • Fixed Sound, Thanks ComputerFreak!
    11 Mar 2011 | Cronos Ginger 1.3.0
    • Updated to latest Sources.
    • Added new Kernel Build.
    • Fixed Music.
    • Better Memory utilization.
    • Patched libfreetype for better rendering of fonts.
    • Added Battery Drain kernel and binary fixes. (Thanks hrkfdn and mad-murdock).
    07 Mar 2011 | Cronos Ginger 1.2.0
    • Fresh full clean Sources (Again..)
    • Fixed WiFi/3G Bug.
    • Unlocked Android 2.3 Audio effects for Music Player.
    • Removed DSPManager.
    • CM Extra updated to latest version.
    • Fixed Bluetooth.
    • Fixed Sound Bug.
    03 Mar 2011 | Cronos Ginger 1.1.0
    • Updated to sources 2.3.3.
    • Included latest Kernel (09).
    • Changed format to EXT4.
    Known bugs:
    • Enable Wifi does not stop Mobile data. Please disable Mobile Data to make wifi work correctly.
    • Included kernel does not boot up. Please flash kernel 09 after flashing the rom.
    20 Feb 2011 | Cronos Ginger 1.0.0
    • Fully ARM optimized compile.
    • Added latest CM Functions into CM extra.
    • Fast booting included.
    • Launcher2 included as default Launcher.
    • Animations have been speeden up a lot.
    • Improved EGL.
    • 2G/3G/H Supported.
    • WiFi Speed improvements.
    • CM Default Kernel included for now. Until I get these DHD sources working.
Download CGX-1.7.0:
Cronos Official Mirror:
PHP Bertol Cronos Mirror
MD5SUM: on download link.
Latest gapps::
goo-inside.me - 7 downloads
Nice! I was a big fan of your HTC Hero gingerbread rom - will definitely be giving this a try.
